2 Pages<12
RoboST
#21 Posted : Thursday, June 14, 2018 3:40:55 PM(UTC)
RoboST
MJPG seems good for our application but since I made changes to the camera config, I decided to resolve a couple things that have been issues in one installation.
One of the vMix version updates did increase overall CPU utilization it appears, most noticeable on older setups. Perhaps it's because we are using NDI and there have been changes there with the newer NDI SDK, I don't know. I believe I have seen forum posts from others about this CPU Utilization after one of the past vMix updates.
This one installation (oldest system in use) also has the largest room, so at 720p the BCC950 zoom maximum was not ideal.
I decided to lower the camera input resolution to 1024 x 576 (still 16:9 & divisible by 8 like 1280 x 720) - gave a little better zoom max (little bit but really not noticeable detail) and also lower overall CPU utilization about 5-8%.
On that one installation, I will keep testing with these new settings with MJPG for the BCC950, vMix still set for 720p30.
mjgraves
#22 Posted : Thursday, June 14, 2018 11:56:26 PM(UTC)
mjgraves
I've also used the CC3000e and PTZ Pro. Those have much more zoom reach.
https://amzn.to/2Mp6mGF
Although at $570, they do cost 3x what the BCC950 costs.
Guest (11)
2 Pages<12
