Basel
#1 Posted : Tuesday, June 5, 2018 4:23:37 AM(UTC)
Basel
I have dual GTX 1080 Ti cards installed in SLI, and when ever the SLI is enabled Vmix goes crazy, the screen flickers like hell, until I turn it off, would you be kind to fix this issue, or let me know a work around.
thanks
#2 Posted : Tuesday, June 5, 2018 4:56:55 AM(UTC)
vMix does not support or benefit from SLI, so you will need to disable it.
Basel on 6/17/2018(UTC)
Basel
#3 Posted : Sunday, June 17, 2018 11:13:29 AM(UTC)
Basel
After I updated to the latest version it doesn't show that flickering any more, did you just fix it?.... after having this issue since last year I'm so glad I addressed the elephant in the room by bring it up. so thanks Martin.
Basel
