Thanks: 2 times Was thanked: 2 time(s) in 1 post(s)
I have dual GTX 1080 Ti cards installed in SLI, and when ever the SLI is enabled Vmix goes crazy, the screen flickers like hell, until I turn it off, would you be kind to fix this issue, or let me know a work around.
thanks
Joined: 1/13/2010(UTC) Posts: 5,350  Location: Gold Coast, Australia Was thanked: 4758 time(s) in 1633 post(s)
vMix does not support or benefit from SLI, so you will need to disable it.
Martin vMix
After I updated to the latest version it doesn't show that flickering any more, did you just fix it?.... after having this issue since last year I'm so glad I addressed the elephant in the room by bring it up. so thanks Martin.
Baseladmin wrote:vMix does not support or benefit from SLI, so you will need to disable it.
Martin vMix
