Vuurmannetje
#1 Posted : Thursday, May 31, 2018 2:57:44 PM(UTC)
Vuurmannetje
Was thanked: 33 time(s) in 19 post(s)
Hi again!
So, last update solved my plugin issues with VST3. But now it seems that my mastering plugin doesnt get its latency (170ms about) compensated. Now I found that I can re-sync lipsync on all my actors on the individual audio channels with negative delay, but there must be a better way!
So several things I can think of:
- Enable the same delay option on the master bus, including going negative, so I can manually compensate there.
- Program some sort of automatic delay compensation.
- Display measured desync somewhere so I can manually exactly sync easily.
Cheers,
v
