Feature Requests
Audio re-syncing tools on master
Joined: 5/14/2018(UTC) Posts: 115 Location: Netherlands
Thanks: 3 times Was thanked: 33 time(s) in 19 post(s)
Hi again!
So, last update solved my plugin issues with VST3. But now it seems that my mastering plugin doesnt get its latency (170ms about) compensated. Now I found that I can re-sync lipsync on all my actors on the individual audio channels with negative delay, but there must be a better way!
So several things I can think of: - Enable the same delay option on the master bus, including going negative, so I can manually compensate there. - Program some sort of automatic delay compensation. - Display measured desync somewhere so I can manually exactly sync easily.
Cheers, v
Feature Requests
