1080I INPUT AND OUTPUT MOTION JERK
Joined: 1/13/2010(UTC) Posts: 5,344  Location: Gold Coast, Australia Was thanked: 4746 time(s) in 1631 post(s)
First, turn off the synchronise output setting, it is only for XP and has no effect on recordings. Second, are you able to upload a short clip to demonstrate the issue?
Also, keep an eye on the dropped frames counter, it may indicate an issue with the graphics card or cpu.
Martin vMix
Joined: 12/20/2012(UTC) Posts: 81  Location: INDIA, TAMILNADU Thanks: 5 times Was thanked: 8 time(s) in 6 post(s)
admin wrote:First, turn off the synchronise output setting, it is only for XP and has no effect on recordings. Second, are you able to upload a short clip to demonstrate the issue?
Martin vMix problem solved. problem from frmerate. addinput file frame 25, but file property show 50 frame. i will restart vmix. i try again now is ok. thanku
