#1 Posted : Wednesday, November 13, 2013 11:22:27 AM(UTC)
First, turn off the synchronise output setting, it is only for XP and has no effect on recordings.
Second, are you able to upload a short clip to demonstrate the issue?
Also, keep an eye on the dropped frames counter, it may indicate an issue with the graphics card or cpu.
amsudeen
#2 Posted : Thursday, November 14, 2013 2:49:58 AM(UTC)
amsudeen
Was thanked: 8 time(s) in 6 post(s)
problem solved. problem from frmerate. addinput file frame 25, but file property show 50 frame. i will restart vmix.
i try again now is ok.
thanku
