Joined: 5/24/2018(UTC) Posts: 20   Location: Worthing
Hi
I have been using the beta 21.0.0.32 version of vMix with no problems.
I upgraded to the release version .42 and I have been having frequent and regular crashes. It seems to be related to audio. I have a background mp3 file playing during the stream and after about 5 minutes the audio starts to stutter badly. Eventually, I get a Windows message to tell me that vMix has crashed.
However, if I leave this the stream continues although I can't interact with vMix. If I click on the Windows message to close it, the whole app closes down.
I have reverted to beta version .32 which runs fine. This leads me to believe it is a minor change in the release version which has caused my issue.
Is it just me??!! Any ideas appreciated. I have uninstalled and reinstalled from scratch to no avail. Thanks.
Joined: 1/13/2010(UTC) Posts: 5,311  Location: Gold Coast, Australia Was thanked: 4711 time(s) in 1615 post(s)
Hi, With the vMix preset loaded go to Settings -> About and click Send Support Report Then drop us an email to info@vmix.com.au with your key, we should be able to see what is happening, though this is not something we have encountered before. Regards, Martin vMix
Joined: 10/9/2018(UTC) Posts: 28   Location: Leesburg AL Thanks: 1 times Was thanked: 2 time(s) in 2 post(s)
I have now been experiencing this as well with ver 23.0.0.46 There are no notices or messages, vmix just closes on it's own.
Is there a error log and where is it located?
