                Hi Guys,
  I'm trying to write a (vb)script to run onCompleted that writes the input just ran to a text file. I can easily write a text file - i just need to know how to get the input number / name of the source that has just played. (sort of like a log - but just for specific files)
  if there a reference sheet of variables you can get?
  Many thanks
                OneMoreThing wrote:Hi Guys,
  Many thanks  example Code:
 Dim doc As New XmlDocument()
do
doc.LoadXml(API.XML())
Dim id As String = doc.SelectSingleNode("/vmix/active").InnerText
Dim node As XmlNode = doc.SelectSingleNode("/vmix/inputs/input[@number='"+ id +"']")
Dim name As String = node.FirstChild.InnerText
Input.Find("label.xaml").Text("label1") = name
 Loop
   label.xaml param label1
