OneMoreThing
#1 Posted : Tuesday, May 22, 2018 5:40:03 AM(UTC)
OneMoreThing
Hi Guys,
I'm trying to write a (vb)script to run onCompleted that writes the input just ran to a text file.
I can easily write a text file - i just need to know how to get the input number / name of the source that has just played.
(sort of like a log - but just for specific files)
if there a reference sheet of variables you can get?
Many thanks
meboooth
#2 Posted : Wednesday, May 30, 2018 7:44:40 PM(UTC)
meboooth
OneMoreThing wrote:
Hi Guys,
Many thanks
example
Code:
 Dim doc As New XmlDocument()
do
doc.LoadXml(API.XML())
Dim id As String = doc.SelectSingleNode("/vmix/active").InnerText
Dim node As XmlNode = doc.SelectSingleNode("/vmix/inputs/input[@number='"+ id +"']")
Dim name As String = node.FirstChild.InnerText
Input.Find("label.xaml").Text("label1") = name
 Loop
label.xaml param label1
