nsun009
#1 Posted : Friday, May 18, 2018 9:22:48 PM(UTC)
nsun009
Hi vMix
It will be nice to have more than only 4 overlays, maybe 6.
thanks 1 user thanked nsun009 for this useful post.
grantcoll on 7/18/2018(UTC)
grantcoll
#2 Posted : Wednesday, July 18, 2018 1:02:42 AM(UTC)
grantcoll
+1 Yes I would like more. Even if Stingers could be configured to use as overlays that would provide 2 more.
spencerm24
#3 Posted : Wednesday, July 18, 2018 4:04:07 PM(UTC)
spencerm24
+1 while multiview on each input is nice, its not always possible to use those. I max out at 4 and wish I had 6 keyers.
samrikard
#4 Posted : Thursday, August 30, 2018 9:22:02 AM(UTC)
samrikard
+1 a couple of extra overlays would be appreciated
jvphobic
#5 Posted : Friday, August 31, 2018 2:58:25 PM(UTC)
jvphobic
Was thanked: 11 time(s) in 10 post(s)
+1
spencerm24
#6 Posted : Wednesday, September 5, 2018 12:31:45 AM(UTC)
spencerm24
+1
ThomasK
#7 Posted : Thursday, September 6, 2018 9:30:11 AM(UTC)
ThomasK
Austria
+1
#8 Posted : Thursday, September 6, 2018 1:24:30 PM(UTC)
vMix is the most powerful solution on the market in terms of layers.
Just re-think your way of doing things, be creative... With the ability to handle dynamic multiviews (being used by the 4 overlays) you have more than 40 layers at your disposal! Or even 100 if you want... More than enough I believe if you still want to see the video below! And more than enough to get serious headaches at the designing part!!! ;o)
Guillaume
ThomasK on 9/6/2018(UTC)
JAIRODJ
#9 Posted : Thursday, September 6, 2018 2:58:47 PM(UTC)
JAIRODJ
Was thanked: 16 time(s) in 12 post(s)
It would be better to add transitions in the activation of the 10 multiview layers of each entry, that would allow them to be used as overlays
