Hi vMix
It will be nice to have more than only 4 overlays, maybe 6.
 1 user thanked nsun009 for this useful post.
Thanks: 21 times Was thanked: 10 time(s) in 9 post(s)
+1 Yes I would like more. Even if Stingers could be configured to use as overlays that would provide 2 more.
+1 while multiview on each input is nice, its not always possible to use those. I max out at 4 and wish I had 6 keyers.
Joined: 8/24/2016(UTC) Posts: 19 Location: Olive Branch, MS
Thanks: 4 times Was thanked: 5 time(s) in 5 post(s)
+1 a couple of extra overlays would be appreciated
Joined: 6/23/2016(UTC) Posts: 106 Location: Milwaukee
Thanks: 1 times Was thanked: 11 time(s) in 10 post(s)
Joined: 8/11/2018(UTC) Posts: 60   Thanks: 33 times Was thanked: 6 time(s) in 6 post(s)
vMix is the most powerful solution on the market in terms of layers.
Just re-think your way of doing things, be creative... With the ability to handle dynamic multiviews (being used by the 4 overlays) you have more than 40 layers at your disposal! Or even 100 if you want... More than enough I believe if you still want to see the video below! And more than enough to get serious headaches at the designing part!!! ;o)
Guillaume
Joined: 9/1/2015(UTC) Views messages in topic : 128  Location: Ecuador Thanks: 2 times Was thanked: 16 time(s) in 12 post(s)
It would be better to add transitions in the activation of the 10 multiview layers of each entry, that would allow them to be used as overlays
