vMix 20/21 and NVIDIA Quadro with 4 connected display
Hello. I'm using the vMix 4K and the Quadro P4000 GPU. The GPU has 4 DisplayPort outputs. The first output of the GPU is used to work with the vMix GUI. Is it possible to configure vMix 20 or 21 so that Input 1, Input 2 and Input 3 are shown on the other three outputs of the GPU?
Joined: 8/21/2015(UTC) Posts: 324   Location: Cornwall, Ontario, Canada Thanks: 18 times Was thanked: 80 time(s) in 60 post(s)
I use 5 screens with my GTX 750TI and my Blackmagic card external output. With the 4K version, you can have 2 fullscreen outputs only. This what I do with the HD Version (1 fullscreen output only) 1) Screen 1 to display vMix itself 2) Set Display 1 to screen 2 (Multiview) 3) Set Screen 3 to display vMix Universal Title controller 4) Set Screen 4 to display web browser with the different providers I am streaming too. To verify Streams are active and working OK. 5) Set External on Blackmagic (Full Screen / Output / Stream) With the Virtual Outputs will not go to screens directly, you will have to use run 2 instances of NDI Studio Monitor from Newtek to display on the other monitors. akarak wrote:Hello. I'm using the vMix 4K and the Quadro P4000 GPU. The GPU has 4 DisplayPort outputs. The first output of the GPU is used to work with the vMix GUI. Is it possible to configure vMix 20 or 21 so that Input 1, Input 2 and Input 3 are shown on the other three outputs of the GPU?
Joined: 3/20/2014(UTC) Posts: 2,719   Location: Bordeaux, France Thanks: 243 times Was thanked: 796 time(s) in 590 post(s)
Quote:Is it possible to configure vMix 20 or 21 so that Input 1, Input 2 and Input 3 are shown on the other three outputs of the GPU? Sort of... but you will need to go for NDI Monitor for that either via settings up vMix Outputs or simply by using NDI feeds from cam inputs. I wouldn't do it. Normally here's what 4 monitors are used to with vMix: mon1 : vMix UI mon2 : fullscreen PGM mon3 : fullscreen multiview (or preview) mon4 : undocked sound mixer or instant replay When doing this, you still can use vMix Outputs (physical or NDI) for other things which is more interesting in my opinion. Guillaume
