akarak
#1 Posted : Wednesday, May 16, 2018 7:42:51 PM(UTC)
akarak
Hello. I'm using the vMix 4K and the Quadro P4000 GPU. The GPU has 4 DisplayPort outputs. The first output of the GPU is used to work with the vMix GUI. Is it possible to configure vMix 20 or 21 so that Input 1, Input 2 and Input 3 are shown on the other three outputs of the GPU?
desmar
#2 Posted : Wednesday, May 16, 2018 9:27:33 PM(UTC)
desmar
Canada
I use 5 screens with my GTX 750TI and my Blackmagic card external output.
With the 4K version, you can have 2 fullscreen outputs only.
This what I do with the HD Version (1 fullscreen output only)
1) Screen 1 to display vMix itself
2) Set Display 1 to screen 2 (Multiview)
3) Set Screen 3 to display vMix Universal Title controller
4) Set Screen 4 to display web browser with the different providers I am streaming too.
To verify Streams are active and working OK.
5) Set External on Blackmagic (Full Screen / Output / Stream)
With the Virtual Outputs will not go to screens directly, you will have to use run 2 instances of NDI Studio Monitor from Newtek to display on the other monitors.
#3 Posted : Thursday, May 17, 2018 3:42:39 AM(UTC)
Sort of... but you will need to go for NDI Monitor for that either via settings up vMix Outputs or simply by using NDI feeds from cam inputs.
I wouldn't do it. Normally here's what 4 monitors are used to with vMix:
mon1 : vMix UI
mon2 : fullscreen PGM
mon3 : fullscreen multiview (or preview)
mon4 : undocked sound mixer or instant replay
When doing this, you still can use vMix Outputs (physical or NDI) for other things which is more interesting in my opinion.
Guillaume
