Thanks: 6 times Was thanked: 2 time(s) in 2 post(s)
I have a problem to get a H265 stream into Vmix. With the VLC plugin the quality is really bad. I think it's an old version with old H265 codec. Potplayer and VLC 3 show good quality with low latency. I also tried to restream with VLC 3.01 over NDI, but I only get a picture in NDI Monitor. In Vmix I have a black screen. I tried also with VLC 2.2.8 with the same result. Does anyone facing the same problem or is there a known work around? My system:
Latest Vmix (not beta) 4k VLC Plugin NDI tools 3.5 i7 Desktop with 1060 GPU 3GB
Thanks Jürgen
