trilive
#1 Posted : Wednesday, May 16, 2018 8:42:00 AM(UTC)
trilive
I have a problem to get a H265 stream into Vmix. With the VLC plugin the quality is really bad. I think it's an old version with old H265 codec. Potplayer and VLC 3 show good quality with low latency. I also tried to restream with VLC 3.01 over NDI, but I only get a picture in NDI Monitor. In Vmix I have a black screen. I tried also with VLC 2.2.8 with the same result.
Does anyone facing the same problem or is there a known work around?
My system:
Latest Vmix (not beta) 4k
VLC Plugin
NDI tools 3.5
i7 Desktop with 1060 GPU 3GB
Jürgen
