Joined: 9/20/2011(UTC) Posts: 22  Location: Raleigh, NC Thanks: 44 times Was thanked: 3 time(s) in 3 post(s)
Upgraded to Windows 10 (Thank you, thank you :-) and found a few (maybe) bugs, using vMix 20.0.0.55:
1. vMix does not remember "Window Position" when not in 'Start Maximized' and then it does (back and forth), no certain patern.
2. Desktop capture does not work when trying to capture 'Chrome'. Works for Skype, and FF. Capturing 'Display 2' works fine so it is a workaround. When capturing Chrome I get a black screen. I am assuming Chrome problem.
Anybody else seen these? Amnon
Joined: 5/14/2018(UTC) Posts: 115 Location: Netherlands
Thanks: 3 times Was thanked: 33 time(s) in 19 post(s)
Amnon wrote:Upgraded to Windows 10 (Thank you, thank you :-) and found a few (maybe) bugs, using vMix 20.0.0.55:
2. is easy. Disable hardware accelleration in chrome to enable capture
 1 user thanked Vuurmannetje for this useful post.
Vuurmannetje wrote: 2. is easy. Disable hardware accelleration in chrome to enable capture Sure enough!!! Thanks for the quick reply. Amnon
