Amnon
#1 Posted : Monday, May 14, 2018 2:43:39 PM(UTC)
Amnon
Upgraded to Windows 10 (Thank you, thank you :-) and found a few (maybe) bugs, using vMix 20.0.0.55:
1. vMix does not remember "Window Position" when not in 'Start Maximized' and then it does (back and forth), no certain patern.
2. Desktop capture does not work when trying to capture 'Chrome'. Works for Skype, and FF. Capturing 'Display 2' works fine so it is a workaround. When capturing Chrome I get a black screen. I am assuming Chrome problem.
Anybody else seen these?
Amnon
Vuurmannetje
#2 Posted : Monday, May 14, 2018 2:55:43 PM(UTC)
Vuurmannetje
Was thanked: 33 time(s) in 19 post(s)
Amnon
2. is easy. Disable hardware accelleration in chrome to enable capture
thanks 1 user thanked Vuurmannetje for this useful post.
Amnon on 5/14/2018(UTC)
Amnon
#3 Posted : Monday, May 14, 2018 3:40:04 PM(UTC)
Amnon
Sure enough!!! Thanks for the quick reply.
Amnon
