Backup system - help with improvments please
Thanks: 19 times Was thanked: 4 time(s) in 1 post(s)
I have this as a scripting solution. The sleep is required as when you fade in the input is still not active so therefore no returned in the xml Would be great if anybody had a better solution....
I have to now run this script with every input - maybe a script that runs all the time would be better? Or a script that i run with a blank overlay that loops checking the current input - this then means i can easily stop the backup link...
Ideas gratefully received...
Threading.Thread.Sleep(600) dim xml = API.XML() dim x as new system.xml.xmldocument x.loadxml(xml) dim n = x.SelectSingleNode("//active") Console.WriteLine("Beginning Example Script") Console.WriteLine("http://192.168.1.18:8088/api?Function=Cut&Input="+n.InnerText) Dim client = WebRequest.Create("http://192.168.1.18:8088/api?Function=Cut&Input="+n.InnerText) Dim response = client.GetResponse()
