smudge1977
#1 Posted : Wednesday, May 9, 2018 2:29:57 PM(UTC)
smudge1977
Was thanked: 4 time(s) in 1 post(s)
I have this as a scripting solution. The sleep is required as when you fade in the input is still not active so therefore no returned in the xml
Would be great if anybody had a better solution....
I have to now run this script with every input - maybe a script that runs all the time would be better?
Or a script that i run with a blank overlay that loops checking the current input - this then means i can easily stop the backup link...
Ideas gratefully received...
Threading.Thread.Sleep(600)
dim xml = API.XML()
x.loadxml(xml)
dim n = x.SelectSingleNode("//active")
Console.WriteLine("Beginning Example Script")
Console.WriteLine("http://192.168.1.18:8088/api?Function=Cut&Input="+n.InnerText)
Dim client = WebRequest.Create("http://192.168.1.18:8088/api?Function=Cut&Input="+n.InnerText)
Dim response = client.GetResponse()
