Thanks: 99 times Was thanked: 5 time(s) in 5 post(s)
I have a few short videos from youtube I want to cut up and combine with vmix.
I know that most readers here are super pro serious heavy duty users. Many of you edit video with fancy dedicated high powered programs.
I am looking for a very simple and not too complicated video editing program to just clip some videos and sweeten the sound. Camtasia does this just fine in the old days; but, I don't want to spend 250 USD for a one time use.
Any ideas for a solid program to do this. There are many advertised; but, I have never used any of them.
I appreciate any help and recommendations. Simple, solid and not too expensive.
THANK YOU,
Rob
Joined: 4/18/2016(UTC) Posts: 223 Location: United Kingdom
Thanks: 33 times Was thanked: 37 time(s) in 31 post(s)
Shotcut
Davinci Resolve by Blackmagic
Hitfilm Express
VideoPad (careful when you install it, do a custom install and don't allow it to install any extra rubbish)
 1 user thanked NHT for this useful post.
Oh I should say Hitfilm is the best all round.
Videopad is the easiest to use.
Joined: 3/15/2018(UTC) Posts: 82  Thanks: 5 times Was thanked: 10 time(s) in 8 post(s)
The Best Editing software ever , easy and high professional comes from the Great Company SONY
SONY Vegas pro
Best ever software for video and film production with a high professional result
TRY IT
 1 user thanked marcyaghi1 for this useful post.
marcyaghi1 wrote:The Best Editing software ever , easy and high professional comes from the Great Company SONY
SONY Vegas pro
TRY IT
OP didn't want to spend $250 ! ( let alone way more !)
Joined: 4/14/2013(UTC) Posts: 264  Location: Australia Thanks: 35 times Was thanked: 38 time(s) in 36 post(s)
Resolve is good for editing, it's not that hard to get started and something you will never grow out of.
If you have a fast gpu the `live' mode, sdi to sdi, can do Godrays, blurs and other effects that may be of interest with vMix.
There's also Premier Elements for $100.
 1 user thanked Peter B for this useful post.
Guys, thank you for the great help. I just had a thought. In addition to cutting a little from the beginning of a video clip I wanted to try to reduce a little background hissing .... many of the programs have something to filter sound and sometimes they even work a bit.... so, can i do this somehow with vMix....
I know about the eq; but, maybe there is something I am missing.
thanks AGAIN, Rob
Quote: I wanted to try to reduce a little background hissing .... many of the programs have something to filter sound and sometimes they even work a bit.... so, can i do this somehow with vMix. For this you can try to use a VST3 plugin. I can recommend those from Waves which are fantastic Check X-Noise or Z-Noise or W43 for example There is a free trial available and if you are happy with one of them, the link below will give you (or anyone else) 10% discount https://www.waves.com/r/fgcn5qGuillaume
You have been a member since:: 8/20/2014(UTC) Posts: 388
Originally Posted by: ovinas  https://www.videohelp.com/software/sections/video-editors-advanced
My favourite: Shotcut My favourite video editor too!
Joined: 6/28/2021(UTC) Views messages in topic : 3  Location: New York
Originally Posted by: marcyaghi1  The Best Editing software ever , easy and high professional comes from the Great Company SONY
SONY Vegas pro
TRY IT
I used it before, really good software. Now I started using Movavi Screen Recorder 2021. For me, this is the best option, because here I can record my performances and then process them. I can record sounds separately from the screen recording, which is very convenient. In terms of functionality and capabilities, it completely suits me.
