ndi desktopcapture virtual input behaviour
Joined: 3/7/2012(UTC) Posts: 506  Location: The Netherlands Thanks: 9 times Was thanked: 45 time(s) in 39 post(s)
first of all - congrats to Martin and team for a very succesfull NAB - a stellar product from a stellar team based on stellar users support and feedback.
So it increasingly hard to find a 'problem' but maybe a got one ( small, non critical, insignificant, ... but still a problem )...
I am specialized in recording knowledge sessions where a speaker talks and uses a powerpoint. I prefer the speaker to use a 4by3 pp slide because this fits nicely in a 16by9 frame leaving space to include the speaker.
but frequently slides of 16:9 are used, so I have to sqeeze this in, making the resulting frame smaller and letterboxed if I keep the pp input 16:9.
But I thought of a sollution: I make a virtual input of the ndi pp desktopcapture input and set this input to normal. thisway the virtual input is made 4by 3 and I can use both. For basic pp slides woth text this is no problem, and I also prepare a 16:9 pp overlay.
but the normal setting is not retained in a preset. so in case I have to restart i have to reset the input setting of the virtual input.
further: using a merge transition the transition is not smooth and seems to jump from 16:9 to the 4:3 normal setting during the transition.
so again, nothing much but at least there is something to note on an otherwise perfect product!!
stefan
