Joined: 5/24/2014(UTC) Posts: 46   Location: Brazil Thanks: 54 times Was thanked: 5 time(s) in 3 post(s)
Hello Vmix people, how about the possibility of copying and pasting or exporting and importing the program's Trigger command. That would be very usual. I quite use the Triggers Thank you.
Joined: 2/23/2017(UTC) Posts: 189  Thanks: 1 times Was thanked: 52 time(s) in 42 post(s)
Reinaldo wrote:Hello Vmix people, how about the possibility of copying and pasting or exporting and importing the program's Trigger command. That would be very usual. I quite use the Triggers Thank you. Workaround I use is to create Virtual Input of the input that has triggers, then change out the created Virtual Input to Camera/etc. Triggers will be left on the new input.
 1 user thanked MartLeib for this useful post.
