Reinaldo
#1 Posted : Monday, April 2, 2018 10:25:40 AM(UTC)
Reinaldo
Brazil
Hello Vmix people, how about the possibility of copying and pasting or exporting and importing the program's Trigger command.
That would be very usual.
I quite use the Triggers
Thank you.
MartLeib
#2 Posted : Thursday, April 5, 2018 8:28:43 AM(UTC)
MartLeib
Estonia
Thank you.
Workaround I use is to create Virtual Input of the input that has triggers, then change out the created Virtual Input to Camera/etc. Triggers will be left on the new input.
thanks 1 user thanked MartLeib for this useful post.
Reinaldo on 4/20/2018(UTC)
