rowby
#1 Posted : Friday, March 23, 2018 11:14:55 AM(UTC)
rowby
Views messages in topic : 330
Hello Everyone,
Today I did a test of vMix call and instead of the main output (program) being returned to the vMix caller he was seeing my webcam output.
Not sure what I may have done in settings to cause this, but is the output that is returned to the vMix callers selectible?
I assume by default it's sending the program output, but for some reason I did something and he's seeing my webcam output instead.
Thanks,
Rowby
rowby
#2 Posted : Friday, March 23, 2018 11:22:02 AM(UTC)
rowby
Hi Rowby,
If you would have looked at the vMix Call documentation before making this post you would have seen that yes, you can easily select what is sent back to the caller.
https://www.vmix.com/hel...index.htm?VideoCall.html
Video Source: Select either Output 1, Output 2-4 (4K and Pro editions only) or None as the return video feed the remote guest will see
If None is selected, no audio or video will be sent to the remote guest, this is useful for situations where you need a remote feed only and don't expect to interact
with the caller.
Rowby
