	vMix Call
	Selecting what input goes back to the vMix callers
 Joined: 11/23/2016(UTC) Posts: 330  Location: USA Thanks: 179 times Was thanked: 26 time(s) in 25 post(s)
                Hello Everyone,
  Today I did a test of vMix call and instead of the main output (program) being returned to the vMix caller he was seeing my webcam output.
  Not sure what I may have done in settings to cause this, but is the output that is returned to the vMix callers selectible?
  I assume by default it's sending the program output, but for some reason I did something and he's seeing my webcam output instead.
  Thanks, Rowby
                Hi Rowby,  If you would have looked at the vMix Call documentation before making this post  you would have seen that yes, you can easily select what is sent back to the caller.  https://www.vmix.com/hel...index.htm?VideoCall.html Quote:Video Source: Select either Output 1, Output 2-4 (4K and Pro editions only) or None as the return video feed the remote guest will see
  If None is selected, no audio or video will be sent to the remote guest, this is useful for situations where you need a remote feed only and don't expect to interact with the caller.  Regards, Rowby
	vMix Call
