atwsportscast
#1 Posted : Tuesday, March 20, 2018 1:12:10 PM(UTC)
atwsportscast
I have a golf tournament coming up and was wondering if Vmix Call would work well for this. Good Wifi and hard line internet connection won`t be a problem here. I`m just wondering about the quality of the signal I will be sending back to the computer that will be taking the calls.
I will be using three computers that I already have Vmix installed on and I do 1080 on all of them with no problem and broadcast live to a youtube channel.
I do use laptops, but not cheap ones. If I need to use a desk top as the receive computer I can do that also.
What kind of quality can I get? Will I be able to get 29.97 frame rate with this setup?
TuesdaysLive
#2 Posted : Tuesday, March 20, 2018 1:32:48 PM(UTC)
TuesdaysLive
Was thanked: 15 time(s) in 13 post(s)
On all calls we've done, each was a maximum of 15fps, with 720p video, dependent upon connection speed at the remote end.
atwsportscast
#3 Posted : Tuesday, March 20, 2018 1:39:48 PM(UTC)
atwsportscast
My plan is to have laptops running Vmix at the holes we plan on cover. Pretty much how you would do a sports event.
Didn`t know if this would help the frame rates and quality since all the calls would be coming from machines running Vmix.
And thanks for the quick reply!
rowby
#4 Posted : Tuesday, March 20, 2018 2:19:41 PM(UTC)
rowby
Hi.
A little off topic, but might be if interest to you. .....
This Tim Sinclair “Streaming Idiots”episode.using vMix and WiFi etc should be helpful. Basketball Stadium.
And another one.
Rowby
TuesdaysLive
#5 Posted : Wednesday, March 21, 2018 8:26:51 AM(UTC)
TuesdaysLive
That's is a very good question. However, since our call have never been initiated or received from another vMix, I can't answer it.
Perhaps, the best thing to do is actually test your setup to determine the fps and quality, at your in-house studio lab. At least you'd have an idea of what to expect, even if the connectivity speeds and other conditions might be different at your event location.
atwsportscast
#6 Posted : Wednesday, March 21, 2018 1:01:39 PM(UTC)
atwsportscast
I agree on that TL.
I have my laptops out with my crew right now and just had an idea on trying this.
Thanks!
Barney Box Lane
#7 Posted : Thursday, March 22, 2018 9:23:18 AM(UTC)
Barney Box Lane
Was thanked: 33 time(s) in 29 post(s)
let us know how it goes, we're planning on using vmix call but just as a field monitor on little Windows tablets
