rowby
#1 Posted : Wednesday, March 14, 2018 4:52:28 PM(UTC)
rowby
Hello Everyone,
I want to reset my vMix settings to "Default" -- but only for the current preset that I am working on.
So if i click on the "Default" button, if I later open a different preset (for a different project) will the vMix settings have also been reset to "Default" (I don't want that to happen....) :)
https://www.vmix.com/hel...tm?AdvancedSettings.html
Import/Export/Default
Settings ››
Import
Import all settings from file. This includes all settings configurable from the Settings window.
Export
Export all settings to file. These settings can be imported from any other vMix installation as long as the version is the same.
Default
Restores settings to when vMix was first installed.
Rowby
ovinas
#2 Posted : Thursday, March 15, 2018 9:49:37 AM(UTC)
ovinas
AFAIK no settings are stored in the presets.
If you want presets with different settings you have to use export/import in addition to your preset file.
