Does Settings "Default" button work globally or just for current preset
Joined: 11/23/2016(UTC) Posts: 330  Location: USA Thanks: 179 times Was thanked: 26 time(s) in 25 post(s)
Hello Everyone, I want to reset my vMix settings to "Default" -- but only for the current preset that I am working on. So if i click on the "Default" button, if I later open a different preset (for a different project) will the vMix settings have also been reset to "Default" (I don't want that to happen....) :) https://www.vmix.com/hel...tm?AdvancedSettings.htmlImport/Export/Default Settings ›› Import Import all settings from file. This includes all settings configurable from the Settings window. Export Export all settings to file. These settings can be imported from any other vMix installation as long as the version is the same. Default Restores settings to when vMix was first installed. Thanks Rowby
Rank:: Advanced Member
AFAIK no settings are stored in the presets. If you want presets with different settings you have to use export/import in addition to your preset file.
