Hardware Compatibility
Asus ROG G752VT and Sonnet Echo Thunderbolt 3
Joined: 11/29/2016(UTC) Posts: 75  Location: Italy Thanks: 1 times Was thanked: 4 time(s) in 3 post(s)
Hi, I've found an Asus ROG G752VT for a very good price from a friend. Specs:
I7-6700HQ GTX970M with 3GB ram 16GB DDR4 17'' screen with G-Sync 256GB SSD 500GB HDD 7200 rpm
Will it work with Sonnet Echo via Thunderbolt 3? Has the GTX970M enough power to handle 4x1080p inputs from a Decklink Duo 2, record and replay? HDD will be replaced with 1TB SSD for replay.
Joined: 11/23/2016(UTC) Posts: 330  Location: USA Thanks: 179 times Was thanked: 26 time(s) in 25 post(s)
Not a exact response to your question. But see Martin’s response to a vMix Call forum post Quote:Hi,
For the benefit of other users who may run into this problem in the future, we received a support report and we think the issue is due to the laptop being used being overloaded (either CPU or GPU) by a lot of inputs and simultaneous callers.
As a result the stream was running only at 23fps out of 29.97p.
For those looking to use multiple guests in their production (more than 2), I would advise against using a laptop as the CPU is usually a lot slower than a PC and can actually throttle suddenly if the laptop gets too hot.
But as always, keep an eye on the CPU and Render Time during pre-show. 60% is a safe maximum level for the CPU Under 20ms is safe for Render Time on a 29.97p production. Check these values during pre-show or testing while all inputs that will be need to be used are active.
Regards, ‘ Martin vMix Rowby
Thanks: 12 times Was thanked: 1 time(s) in 1 post(s)
Hi! I have this equipment. The 4 cameras are no problem. I have not tried to play back Gyapi rinaldo wrote:Hi, I've found an Asus ROG G752VT for a very good price from a friend. Specs:
Gyapi wrote:Hi! I have this equipment. The 4 cameras are no problem. I have not tried to play back Gyapi rinaldo wrote:Hi, I've found an Asus ROG G752VT for a very good price from a friend. Specs:
Thanks Gyapi! Have you tried streaming and recording in 2 different formats?
Hi!
VMIX HD only one recording is allowed! I have not tried yet, sorry!
Tried mine today. It's working quite well with 1x1080-50p input and replay. Tomorrow I will change 1TB hdd to ssd and give a try with 4x1080i replay and recording. Nice bought for 800€ and still 1 year warranty.... Gyapi wrote:Hi!
