rinaldo
#1 Posted : Tuesday, March 6, 2018 12:47:31 PM(UTC)
rinaldo
Hi, I've found an Asus ROG G752VT for a very good price from a friend.
Specs:
I7-6700HQ
GTX970M with 3GB ram
16GB DDR4
17'' screen with G-Sync
256GB SSD
500GB HDD 7200 rpm
Will it work with Sonnet Echo via Thunderbolt 3? Has the GTX970M enough power to handle 4x1080p inputs from a Decklink Duo 2, record and replay?
HDD will be replaced with 1TB SSD for replay.
rowby
#2 Posted : Tuesday, March 6, 2018 1:13:19 PM(UTC)
rowby
Not a exact response to your question. But see Martin’s response to a vMix Call forum post
For the benefit of other users who may run into this problem in the future, we received a support report
and we think the issue is due to the laptop being used being overloaded (either CPU or GPU) by a lot of inputs and simultaneous callers.
As a result the stream was running only at 23fps out of 29.97p.
For those looking to use multiple guests in their production (more than 2), I would advise against using a laptop as the CPU is usually a lot slower
than a PC and can actually throttle suddenly if the laptop gets too hot.
But as always, keep an eye on the CPU and Render Time during pre-show. 60% is a safe maximum level for the CPU
Under 20ms is safe for Render Time on a 29.97p production.
Check these values during pre-show or testing while all inputs that will be need to be used are active.
Rowby
Gyapi
#3 Posted : Wednesday, March 7, 2018 5:28:31 PM(UTC)
Gyapi
Hi!
I have this equipment.
The 4 cameras are no problem.
I have not tried to play back
Gyapi
Specs:
I7-6700HQ
16GB DDR4
256GB SSD
500GB HDD 7200 rpm
rinaldo
#4 Posted : Saturday, March 10, 2018 9:53:40 AM(UTC)
rinaldo
Gyapi wrote:
Hi!
Gyapi
Specs:
I7-6700HQ
16GB DDR4
256GB SSD
500GB HDD 7200 rpm
Thanks Gyapi! Have you tried streaming and recording in 2 different formats?
Gyapi
#5 Posted : Saturday, March 10, 2018 2:30:54 PM(UTC)
Gyapi
Hi!
VMIX HD
only one recording is allowed!
I have not tried yet, sorry!
rinaldo
#6 Posted : Sunday, March 11, 2018 11:43:35 PM(UTC)
rinaldo
Tried mine today. It's working quite well with 1x1080-50p input and replay.
Tomorrow I will change 1TB hdd to ssd and give a try with 4x1080i replay and recording.
Nice bought for 800€ and still 1 year warranty....
Gyapi wrote:
Hi!
VMIX HD
