Ittaidv
#1 Posted : Wednesday, February 28, 2018 4:18:31 PM(UTC)
Ittaidv
It would be cool if we were able to select the NIC for Tally and NDI.
Right now, if you use NDI over a wired network, let's say it's one that doesn't have wifi, and you use tally over wifi, you can't use both at the same time.
It's not always a matter of buying a router that does both: say you're in a venue that has cabled ethernet, which you use for NDI, while you brought a wireless router for your tally. Depending on which NIC was active when vMix starts, the IP is used in vMix as the tally IP. Also the other way around: NDI sources are not found, when the tally ip is on the wireless router.
rowby
#2 Posted : Wednesday, February 28, 2018 5:12:35 PM(UTC)
rowby
+! ...Rowby.
MWilson
#3 Posted : Monday, May 21, 2018 10:22:31 PM(UTC)
MWilson
+1 for sure, would be very handy.
#4 Posted : Tuesday, May 22, 2018 7:10:58 AM(UTC)
This should already be possible.
To explain, the web address in Settings -> Web Controller shows the first IP address in the system, but it is actually enabled on all of them
using the same port.
On the NDI side of things, since the latest updates in 20 and 21, NDI will now find sources across multiple network adapters.
