Feature Requests
Select NIC for tally and NDI
It would be cool if we were able to select the NIC for Tally and NDI.
Right now, if you use NDI over a wired network, let's say it's one that doesn't have wifi, and you use tally over wifi, you can't use both at the same time.
It's not always a matter of buying a router that does both: say you're in a venue that has cabled ethernet, which you use for NDI, while you brought a wireless router for your tally. Depending on which NIC was active when vMix starts, the IP is used in vMix as the tally IP. Also the other way around: NDI sources are not found, when the tally ip is on the wireless router.
Joined: 11/23/2016(UTC) Posts: 330  Location: USA Thanks: 179 times Was thanked: 26 time(s) in 25 post(s)
Joined: 6/6/2017(UTC) Posts: 40 Location: Mississippi, United States
Thanks: 8 times Was thanked: 2 time(s) in 2 post(s)
+1 for sure, would be very handy.
Joined: 1/13/2010(UTC) Posts: 5,311  Location: Gold Coast, Australia Was thanked: 4711 time(s) in 1615 post(s)
This should already be possible. To explain, the web address in Settings -> Web Controller shows the first IP address in the system, but it is actually enabled on all of them using the same port.
On the NDI side of things, since the latest updates in 20 and 21, NDI will now find sources across multiple network adapters.
Feature Requests
