moreno7798
#1 Posted : Friday, February 9, 2018 10:27:17 AM(UTC)
moreno7798
For some reason every once in a while PowerPoints go dark and display as "Offline" when I open vMix (see image below). The only way to fix the problem is to re add the powerpoint slide. Is there a fix for this?
samrikard
#2 Posted : Friday, February 9, 2018 11:44:59 AM(UTC)
samrikard
I use Powerpoint everyday in vMix and this happens from time to time. I have found, if I place my cursor over the module, and right click my mouse, I can select, reset (I believe). The module goes away for a couple of seconds, then reappears with the slide show loaded.
thanks 1 user thanked samrikard for this useful post.
Andrew Rix on 10/31/2020(UTC)
