PowerPoint "Offline" in vMix
Joined: 4/7/2017(UTC) Posts: 3 Location: Fort Lauderdale, FL USA
For some reason every once in a while PowerPoints go dark and display as "Offline" when I open vMix (see image below). The only way to fix the problem is to re add the powerpoint slide. Is there a fix for this?
Joined: 8/24/2016(UTC) Posts: 19 Location: Olive Branch, MS
Thanks: 4 times Was thanked: 5 time(s) in 5 post(s)
I use Powerpoint everyday in vMix and this happens from time to time. I have found, if I place my cursor over the module, and right click my mouse, I can select, reset (I believe). The module goes away for a couple of seconds, then reappears with the slide show loaded.
 1 user thanked samrikard for this useful post.
