rowby
#1 Posted : Sunday, February 4, 2018 6:44:25 PM(UTC)
rowby
Hello Everyone,
I find that it's too easy to accidentally switch a multiview input item with an inadvertent roll of a mouse wheel.
The switch from one input to another unintended input can happen so quickly and subtlety that it can go unnoticed -- until a live production shows the mistake.
There have also been times, during pre-show setup, when I accidentally changed an input and am still in the Multiview panel -- and I really can't remember which input was supposed to be there. In that case I have sometimes had to control-alt-delete and force vMix to close without saving in order to bring back the multiview before the accidental switcheroo.
If the Multiview had locks -- similar to "layer locks" found in other graphic programs -- that would solve the issue.
See my mockup attached. I would think any vMix user would be thrilled to see this "locked enabled" Multiview interface in an upcoming upgrade. :)
Thanks!
...Rowby.
rowby attached the following image(s):
