Joined: 11/23/2016(UTC) Posts: 330  Location: USA Thanks: 179 times Was thanked: 26 time(s) in 25 post(s)
Hello Everyone, I find that it's too easy to accidentally switch a multiview input item with an inadvertent roll of a mouse wheel. The switch from one input to another unintended input can happen so quickly and subtlety that it can go unnoticed -- until a live production shows the mistake. There have also been times, during pre-show setup, when I accidentally changed an input and am still in the Multiview panel -- and I really can't remember which input was supposed to be there. In that case I have sometimes had to control-alt-delete and force vMix to close without saving in order to bring back the multiview before the accidental switcheroo. If the Multiview had locks -- similar to "layer locks" found in other graphic programs -- that would solve the issue. See my mockup attached. I would think any vMix user would be thrilled to see this "locked enabled" Multiview interface in an upcoming upgrade. :) Thanks! ...Rowby. rowby attached the following image(s):  locked-multiview-999.jpg (87kb) downloaded 4 time(s).You cannot view/download attachments. Try to login or register.
