Hardware Compatibility
HELP!!! system requirements of vMix
Thanks: 1 times Was thanked: 6 time(s) in 5 post(s)
I try to assembled computer for 4 HD video multicoder record + main record + sreaming. I want to ask about system requirements of vMix. I have: CPU: Intel Core i7 3930K; Motherboard: asus p9x79-e ws; RAM: 16 gb. HDD: 7200 RPM Hard Drive and Solid State Disk
My problem is droped frame on multicoder. Recorder resolution just PAL. I use one, two and thee inputs from Blackmagic cards. I think this is problem of my graphics cards. I try two difference GPU card's. nVidia quadro FX 570 256 MB DDR2 SDRAM 128-bit and Sparkle GeForce GT 220, 1GB DDR2. Maybe someone can recommend a graphics card to be consistent with the 4 HD video multicoder record + main record + sreaming? Maybe there is any method to calculate graphics card?
Sorry for my English
Joined: 1/13/2010(UTC) Posts: 5,325  Location: Gold Coast, Australia Was thanked: 4728 time(s) in 1620 post(s)
Those graphics cards are quite slow. You will likely need something like a nVidia 650
Martin vMix
