artciukas
#1 Posted : Thursday, October 10, 2013 5:32:05 AM(UTC)
artciukas
I try to assembled computer for 4 HD video multicoder record + main record + sreaming.
I want to ask about system requirements of vMix.
I have:
CPU: Intel Core i7 3930K;
Motherboard: asus p9x79-e ws;
RAM: 16 gb.
HDD: 7200 RPM Hard Drive and Solid State Disk
My problem is droped frame on multicoder. Recorder resolution just PAL. I use one, two and thee inputs from Blackmagic cards. I think this is problem of my graphics cards. I try two difference GPU card's. nVidia quadro FX 570 256 MB DDR2 SDRAM 128-bit and Sparkle GeForce GT 220, 1GB DDR2.
Maybe someone can recommend a graphics card to be consistent with the 4 HD video multicoder record + main record + sreaming?
Maybe there is any method to calculate graphics card?
Sorry for my English
#2 Posted : Friday, October 11, 2013 5:47:59 AM(UTC)
Those graphics cards are quite slow. You will likely need something like a nVidia 650
artciukas
#3 Posted : Monday, November 25, 2013 7:26:50 AM(UTC)
artciukas
Hello Martin,
Next week i want to buy graphics card. And my queation is:
What is priority work with vmix. Graphics clock speed or memory size and memory bus speed?
I want to choose from these models:
http://www.gigabyte.us/p...ct-page.aspx?pid=4710#ov
http://www.gigabyte.us/p...ct-page.aspx?pid=4629#ov
MODELS v.s. information:
http://www.gigabyte.us/p...?ck=3&pids=4629,4710
My problem i write before in this post.
p.s.
best manufacturer your opinion is: ASUS,GAINWARD, GIGABYTE, MSI or ZOTAC.
Thanks for answer.
Guest (5)
