Guillem
#1 Posted : Wednesday, January 24, 2018 12:41:45 PM(UTC)
Guillem
Rank:: Newbie
I am new to the Vmix and I want to make a Videocall of 2 points.
The transmitter has to make a presentation with powerpoint and does not have the Vmix software.
Can it be done without software?
mjgraves
#2 Posted : Thursday, February 1, 2018 2:49:23 PM(UTC)
mjgraves
Maybe...there's a browser extension for Chrome called Reflect. It lets a user put their webcam into a window on theier desktop. That way if they share the desktop their image is included as well.
https://www.mgraves.org/...with-reflect-for-chrome/
You could get the presenters Powerpoint deck and present it from your vMix system. You'd need to control the slide playback, but you could send them a return feed so knew were they were.
You may be able to have them establish two vMix Call connections; one from Firefox and the other from Chrome. That way one could be the webcam and another the shared presentation.
All of these things require some effort/coordination/skill/practice.
Guillem on 2/2/2018(UTC)
Guillem
#3 Posted : Friday, February 2, 2018 5:50:41 AM(UTC)
Guillem
Rank:: Newbie
thanks for your ideas ;)
ask
#4 Posted : Friday, February 2, 2018 3:16:50 PM(UTC)
ask
Try NDI Scan Converter from Newtek. Its part of the free NDI tools and there is a portable version that can be run from a USB stick.
mjgraves
#5 Posted : Saturday, February 3, 2018 2:15:05 PM(UTC)
mjgraves
How would that be used with a remote participants presentation?
Light Channel DK
#6 Posted : Thursday, September 26, 2019 7:50:23 PM(UTC)
Light Channel DK
Denmark
How would you do that? The browser is asking for a camera when logged on vmix call.
mjgraves
#7 Posted : Saturday, September 28, 2019 1:16:56 AM(UTC)
mjgraves
NDI Scan Convertor will not do this.
On a Windows PC you could use the Logitech Capture application. It allows you have two sources; a webcam and desktop screen capture. You can create a composite shot that gets passed to vMix call as a virtual webcam.
If your guest is not very technical you might have to help them get this setup. I'd use TeamViewer for that.
