Joined: 6/15/2015(UTC) Posts: 26  Location: Athens, Greece Thanks: 21 times Was thanked: 1 time(s) in 1 post(s)
Im getting render time around 40ms on brand new MSI GTX 1060 Armor OCV1 3GB.Desktop pc.(Coming from gtx 960 2GB)
I tick Enable optimus graphics compatibility and render time falls to 2ms.
Did i solve the problem or just hide it.
Joined: 11/23/2016(UTC) Posts: 330  Location: USA Thanks: 179 times Was thanked: 26 time(s) in 25 post(s)
 1 user thanked rowby for this useful post.
Finally uninstalling Nvidia Experience solved it.
Thanks for the heads up
STERGI
Thanks: 18 times Was thanked: 2 time(s) in 2 post(s)
It should be okay to set this for the actual vMix64.exe application (under Program Settings tab) vs Global Settings (Global Settings tab), correct? ** Manage 3D settings and set Power Management Mode to "Prefer Maximum Performance" ** Also, if we always want to you the nVidia card with vMix, should we just leave "Enable Optimus Graphics comparability" unchecked in vMix (Settings/Performance)? what exactly is that Optimus setting (if enabled) doing with vMix? .
