stergi
#1 Posted : Saturday, January 20, 2018 1:42:37 PM(UTC)
stergi
Im getting render time around 40ms on brand new MSI GTX 1060 Armor OCV1 3GB.Desktop pc.(Coming from gtx 960 2GB)
I tick Enable optimus graphics compatibility and render time falls to 2ms.
Did i solve the problem or just hide it.
rowby
#2 Posted : Saturday, January 20, 2018 9:35:17 PM(UTC)
rowby
Forum Rank:: Advanced Member
Views messages in topic : 330
Hi sterling
Not sure if this page will help you.
https://www.vmix.com/kno...2/optimising-performance
Rowby
thanks 1 user thanked rowby for this useful post.
stergi on 1/29/2018(UTC)
stergi
#3 Posted : Wednesday, January 31, 2018 2:37:57 PM(UTC)
stergi
Finally uninstalling Nvidia Experience solved it.
Thanks for the heads up
STERGI
RoboST
#4 Posted : Wednesday, May 30, 2018 4:34:52 PM(UTC)
RoboST
rowby wrote:
Hi sterling
Rowby
It should be okay to set this for the actual vMix64.exe application (under Program Settings tab) vs Global Settings (Global Settings tab), correct?
** Manage 3D settings and set Power Management Mode to "Prefer Maximum Performance" **
Also, if we always want to you the nVidia card with vMix, should we just leave "Enable Optimus Graphics comparability" unchecked in vMix (Settings/Performance)?
what exactly is that Optimus setting (if enabled) doing with vMix?
