Hi there, i'm new here, so please be patient *smile*.....
shortly, this is my system (fresh build, but older hardware): -Asus Sabertooth X58 Mobo -16GB RAM -Asus 1060 Strix Graphics card -Motu 1224 Audiointerface (PCI Express Card interface with DSP cuemix console) -Universal Audio UAD accelerator card (Audio plugins)
Software: Win 7 64bit vmix v. 20 (newest) Reaper DAW Bluecat Audio Protektor (VST 3, Brickwall Limiter) avast antivirus NO OTHER SOFTWARE, PC ONLY FOR CAPTURING AND STREAMING
I stream mainly dj podcast and live studio music recording sessions. Because i'm a newbie in the 'HDMI capture' world, is there any recommendation for the following streamingtarget: - Audiostream more important than videostream - The rooms aren't well outlighted, so i search a cam, that have the ability to get good results in low light rooms (i know that this is a handicap....!) - streamprovider: dacast
So, my question: I do a long search for HDMI cams, that suits the low light problem, and it ended up with a canon legria (vixia) g20 or 30 (which is quite expensive). But the problem is, that this cam have much of features that i don't need (p. ex.: recording, touchscreen, vibration stabilisator etc.) I only need following attributes: - good performance with low light (big lens) - fixed installation - no features that i listed above - stream in HD - best possible sharpness in the semi-pro range
What cams do you prefer for this? Which capture card should i use (my favorite is the magewell pro 11040 (single hdmi) or dual HDMI version)?
Many thanks
Sascha
a very good camera vs price is the panasonic HC-V777 (or 770). It has a big sensor, a mic input, is switchable pal/ntsc (with a trick). and cost less than 500$. you can even add a PiP from a smartphone
 2 users thanked giroudf for this useful post.
Thanks for the Question, i check out this option! Further, i don't able to choose multibitrate streaming. I can only choose only from one streaming. What do i make wrong? Many thanks for the reply!
