gickosa
#1 Posted : Monday, January 15, 2018 1:17:24 AM(UTC)
gickosa
Hi there, i'm new here, so please be patient *smile*.....
shortly, this is my system (fresh build, but older hardware):
-Asus Sabertooth X58 Mobo
-16GB RAM
-Asus 1060 Strix Graphics card
-Motu 1224 Audiointerface (PCI Express Card interface with DSP cuemix console)
-Universal Audio UAD accelerator card (Audio plugins)
Software:
Win 7 64bit
vmix v. 20 (newest)
Reaper DAW
Bluecat Audio Protektor (VST 3, Brickwall Limiter)
avast antivirus
NO OTHER SOFTWARE, PC ONLY FOR CAPTURING AND STREAMING
I stream mainly dj podcast and live studio music recording sessions. Because i'm a newbie in the 'HDMI capture' world, is there any recommendation for the following streamingtarget:
- Audiostream more important than videostream
- The rooms aren't well outlighted, so i search a cam, that have the ability to get good results in low light rooms (i know that this is a handicap....!)
- streamprovider: dacast
So, my question: I do a long search for HDMI cams, that suits the low light problem, and it ended up with a canon legria (vixia) g20 or 30 (which is quite expensive). But the problem is, that this cam have much of features that i don't need (p. ex.: recording, touchscreen, vibration stabilisator etc.) I only need following attributes:
- good performance with low light (big lens)
- fixed installation
- no features that i listed above
- stream in HD
- best possible sharpness in the semi-pro range
What cams do you prefer for this?
Which capture card should i use (my favorite is the magewell pro 11040 (single hdmi) or dual HDMI version)?
Many thanks
Sascha
giroudf
#2 Posted : Friday, January 19, 2018 4:09:30 PM(UTC)
giroudf
a very good camera vs price is the panasonic HC-V777 (or 770).
It has a big sensor, a mic input, is switchable pal/ntsc (with a trick).
and cost less than 500$.
you can even add a PiP from a smartphone
thanks 2 users thanked giroudf for this useful post.
RobLambert on 1/19/2018(UTC), gickosa on 1/22/2018(UTC)
gickosa
#3 Posted : Monday, January 22, 2018 8:12:05 PM(UTC)
gickosa
Thanks for the Question, i check out this option! Further, i don't able to choose multibitrate streaming. I can only choose only from one streaming. What do i make wrong? Many thanks for the reply!
