AGPtek hdmi extender and Blackmagic Design Intensity Pro 4K HDMI card
Joined: 10/1/2013(UTC) Posts: 196  Location: Bovalino (Italy) Thanks: 86 times Was thanked: 3 time(s) in 3 post(s)
Hello everyone, I have a problem with the combinations in question. I state that both units work perfectly. I bought the Extender hdmi AGPtek, with the Blackmagic Design Decklink Mini Monitor works perfectly, but when I connect it to the "Intensity Pro Pro 4k", it works only if I do "add input" in "video format" I select RGB32. With this setting, however, "instant replay" does not work, as it only works with "UYVY video format". Do you have a solution? Thank you. https://www.amazon.it/gp...01_s00?ie=UTF8&psc=1https://www.bl2.it/it/sc...pro4k-9338716003062.html
maybe I miss some drivers?
do I have to change the extender? :-(
