STADIORADIO
#1 Posted : Saturday, January 13, 2018 9:50:46 AM(UTC)
STADIORADIO
You have been a member since:: 10/1/2013(UTC)
Hello everyone, I have a problem with the combinations in question. I state that both units work perfectly.
I bought the Extender hdmi AGPtek, with the Blackmagic Design Decklink Mini Monitor works perfectly, but when I connect it to the "Intensity Pro Pro 4k", it works only if I do "add input" in "video format" I select RGB32. With this setting, however, "instant replay" does not work, as it only works with "UYVY video format".
Do you have a solution? Thank you.
https://www.amazon.it/gp...01_s00?ie=UTF8&psc=1
https://www.bl2.it/it/sc...pro4k-9338716003062.html
STADIORADIO
#2 Posted : Sunday, January 14, 2018 3:08:33 AM(UTC)
STADIORADIO
A solution?
STADIORADIO
#3 Posted : Sunday, January 14, 2018 5:50:15 PM(UTC)
STADIORADIO
maybe I miss some drivers?
STADIORADIO
#4 Posted : Monday, January 15, 2018 5:58:27 PM(UTC)
STADIORADIO
do I have to change the extender? :-(
Guest (4)
