Element III
#1 Posted : Tuesday, January 9, 2018 6:26:44 AM(UTC)
Element III
Hi everyone ! and happy new year ;)
I made a list for some ideas i've got.
- Make the possibility to have some transition for External output
- possibility to change the input on the multiview screen (change the source)
- Can change in one window all of the titles if they have more than 1 xaml in the scene
- Can add a scene with 10 sources in another to get like 9 more sources
- Can change the zoom position when you create the scene (at this moment we can just zoom in but not move)
- Can create some mix effects known by vmix and can add all the shortcuts accordingly
- Can remove the virtual input behind the name of the scene when u create a virtual input
- Can add a frame around a source in the multiview with the possibility to choose the colour/size etc ...
Thx all ;)
spencerm24
#2 Posted : Wednesday, January 10, 2018 2:17:33 PM(UTC)
spencerm24
Thx all ;)
The ones I'd +1
-Frame on multiview sources
-Change input on multiview screen
Been wanting that for awhile now.
Barney Box Lane
#3 Posted : Thursday, January 11, 2018 12:08:01 PM(UTC)
Barney Box Lane
1
2 if i understand right (to change the source of a picture in picture) could you make the multiview screen a playlist and cut from the playlist?
3
4 that sounds like a multiview in a multiviews which you can do unless I've misunderstood
last - add a custom style frame as a picture in a multiview overlay, or add a colour and you can save the position once you've squared it up nicely
spencerm24
#4 Posted : Thursday, January 11, 2018 12:42:26 PM(UTC)
spencerm24
Barney Box Lane wrote:
1
3
I believe by multiview he isn't referring to on air picture-in-picture, but the multiview output which has all the sources, and output/PVW. At least thats how I took it. Kinda a terminology issue by calling them both multi-view's so I can see how it gets misunderstood.
