Hi everyone ! and happy new year ;)
I made a list for some ideas i've got.
- Make the possibility to have some transition for External output - possibility to change the input on the multiview screen (change the source) - Can change in one window all of the titles if they have more than 1 xaml in the scene - Can add a scene with 10 sources in another to get like 9 more sources - Can change the zoom position when you create the scene (at this moment we can just zoom in but not move) - Can create some mix effects known by vmix and can add all the shortcuts accordingly - Can remove the virtual input behind the name of the scene when u create a virtual input - Can add a frame around a source in the multiview with the possibility to choose the colour/size etc ...
Thx all ;)
Element III wrote:Hi everyone ! and happy new year ;)
Thx all ;) The ones I'd +1 -Frame on multiview sources -Change input on multiview screen Been wanting that for awhile now.
Thanks: 26 times Was thanked: 34 time(s) in 30 post(s)
1 2 if i understand right (to change the source of a picture in picture) could you make the multiview screen a playlist and cut from the playlist? 3 4 that sounds like a multiview in a multiviews which you can do unless I've misunderstood
last - add a custom style frame as a picture in a multiview overlay, or add a colour and you can save the position once you've squared it up nicely
Barney Box Lane wrote:1 2 if i understand right (to change the source of a picture in picture) could you make the multiview screen a playlist and cut from the playlist? 3 4 that sounds like a multiview in a multiviews which you can do unless I've misunderstood
last - add a custom style frame as a picture in a multiview overlay, or add a colour and you can save the position once you've squared it up nicely I believe by multiview he isn't referring to on air picture-in-picture, but the multiview output which has all the sources, and output/PVW. At least thats how I took it. Kinda a terminology issue by calling them both multi-view's so I can see how it gets misunderstood.
