Joined: 10/1/2013(UTC) Posts: 196  Location: Bovalino (Italy) Thanks: 86 times Was thanked: 3 time(s) in 3 post(s)
Good evening. I use triggers for some effects with Instant Replay. But every time I make a new replay setting, I have to re-insert the triggers. Is there a way to export them and then import them to accelerate the times? Thank you
I use Instant Replay a lot, what triggers are you using for this? Can't you just copy/past?
The problem is that it does not make me change the destination folder of "instant replay". Every week we play a different game, and I have to do a new "add input" of "instan replay" and so I always have to insert "Triggers". Unless I'm wrong
Joined: 6/29/2016(UTC) Posts: 102 Location: Luxembourg
Thanks: 48 times Was thanked: 14 time(s) in 12 post(s)
STADIORADIO wrote: Is there a way to export them and then import them to accelerate the times? Thank you
I would like to see a solution for this aswell or alternatively being able to change the replay destination folder. Thanks
