STADIORADIO
#1 Posted : Monday, January 8, 2018 4:37:54 PM(UTC)
STADIORADIO
Good evening. I use triggers for some effects with Instant Replay. But every time I make a new replay setting, I have to re-insert the triggers. Is there a way to export them and then import them to accelerate the times?
Thank you
STADIORADIO
#2 Posted : Tuesday, January 9, 2018 12:03:05 PM(UTC)
STADIORADIO
element
#3 Posted : Tuesday, January 9, 2018 9:01:19 PM(UTC)
element
I use Instant Replay a lot, what triggers are you using for this? Can't you just copy/past?
STADIORADIO
#4 Posted : Wednesday, January 10, 2018 6:13:47 AM(UTC)
STADIORADIO
The problem is that it does not make me change the destination folder of "instant replay". Every week we play a different game, and I have to do a new "add input" of "instan replay" and so I always have to insert "Triggers". Unless I'm wrong
mburel1980
#5 Posted : Wednesday, January 10, 2018 6:43:07 AM(UTC)
mburel1980
Was thanked: 14 time(s) in 12 post(s)
Thank you
I would like to see a solution for this aswell or alternatively being able to change the replay destination folder.
Guest (4)
Similar Topics
Import/export triggers (Feature Requests)
by STADIORADIO 1/12/2018 4:24:10 AM(UTC)
